Home > Wheels & Tyres > Wear on inside edge of both rear tyres, likely cause ?
Baltic Blue
MOT yesterday, passed no problem, but it was pointed out to me that both rear tyres are wearing on the inside edge.
Unfortunately they were very busy when I arrived to pick it up so didn’t get any chance to talk to them to ask likely cause.
Thoughts please.
Post #720282 24th Jun 2025 8:13am
BAZ8046
Hi Mike,
If the rear track control arm, and alignment, are ok it is likely to the upper or lower hub bushes.
I had this on mine and changed the hub bushes along with the track control arm as it was seized.
Laser do a kit so the hub bushes can be changed without taking the hub off which is just threaded bar with the right size cups.
If you do change the track control arm just make sure it has full movement as they tend to wear a slight groove in the slot and you can't get the full adjustment.
I found this out after some head scratching whilst trying to get the alignment in spec.
Hope this helps. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #720284 24th Jun 2025 8:46am
Baltic Blue
Thanks Baz, I will get it all checked out
Cheers
Post #720289 24th Jun 2025 9:31am
