Home > Technical (L405) > PHEV not charging !!
Jetbags
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Hi, I'm really hoping someone has an answer to this issue...
Had christmas tree lights appear on dashboard three days ago, replaced the main culprit, the aux battery which was only showing 4volts.
Battery replaced within 10 minutes as an easy to do job, all lights on dash gone and car running perfectly, or at least thats what i thought.
Used the Autel scanner to do the battery reset, however on selecting the secondary battery option the error message appears "this process did not start" meaning it could not reset the battery module to accept the new battery.
Being that all was working ok i used the car the following day as usual, however when i parked up and plugged the car into the charger it appeared to go into charge mode as usual, but then went into "initiallising" mode and will no longer charge. If i remove the charger and then replace it again it starts charging but then goes back into initialising mode.
Has anyone else had this issue? if so how did you cure it?
It's driving me crazy as there is little or no info anywhere that points to any one fix for this problem.
There are no errors showing on the diagnostics, which for a Range Rover is unheard of !!
Its a 2020 PHEV AB Lwb.
any help gratefully accepted. Why oh why do we buy Range Rovers !!
Post #720425 26th Jun 2025 8:06pm
Mikey
Usually a BeCM issue. Very common on the PHEV
Post #720427 26th Jun 2025 8:23pm
Allseas
Ireland 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Hello Mikey
can you help me please
you did before on RRS
i have a Range Rover Vogue P400e 2019
only 50k miles
my problem is the stop start
in reverse going on off on off
also the full fat now wont charge
i have changed the
main battery
aux battery
battery management system module
high voltage heater
all genuine Land rover parts
i use a
icarsoft LRV3.0 code reader
do you think it is
the BECM
from you experience?
and where is it located??
Post #720665 1st Jul 2025 11:56pm
