![]() | Home > General (L460 2022) > Creaking Behind Dashboard - Legal Position If Unrectifiable |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
No L460 experience, but my 2012 WM had an annoying intermittent buzzing from the dashboard. This turned out to be a build defect. One of the aircon ducts had not been attached properly. The dealer fixed it under warranty and there was no damage to the interior. I sympathise, that sort of thing can drive one up the wall, not helped if passengers comment on it. I have known the dealer I use damage things when doing repairs, but they owned up and replaced the damaged part.
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 834 ![]() ![]() ![]() |
Thank you for taking the time out of your day to reply CS, it's very much appreciated and some good points you make.
The supplying dealer would be the natural first point of call and one would hope you might have some goodwill there having bought at least that car from them. There is also the question whether you know someone sufficiently better to leave "the devil you know". The dealers are the gatekeepers for warranty claims so they will need to support the claim with LR.
Thank you CS, I do have a contact at the supplying dealer from past issues (Service Manager), so will try him and do as you suggest, requesting a test drive together to try and establish the fault.
recordman Member Since: 08 May 2013 Location: Kent Posts: 122 ![]() ![]() ![]() |
The problem with having issues like this looked at and hopefully remedied by main dealers is that they are unlikely to be a straightforward fix and potentially time consuming. The labour rate paid by the manufacturers is not exactly attractive and the remuneration paid to technicians is based on 'book' time, which in this case it's probably not easily ascertained so the job is likely to be rushed.
Thank you for your kind email recordman, it's great to hear from you too, and thank you for your input.
What a beautiful new acquisition! I wish you all the best with your health, new puppy, new mobile fun toy and hope that you can get the annoying noise fixed one way or another. 2017 SDV8 Autobiography |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279 ![]() ![]() |
Sorry delete pm Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Thank you recordman, all the best to you too |
tomo141 Member Since: 22 Aug 2017 Location: UK Posts: 96 ![]() ![]() |
Hi aja500
Thanks for your reply Tomo, that's really interesting - It's funny you should say that, as I said exactly the same thing to my wife only yesterday, the times I have noticed the creaking has been in warmer weather. Maybe something is expanding in the heat behind the dash.
