Home > Technical (L322) > 2008 3.6 TDV8 Air Suspension Fault(with error codes)
Roosterrs
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
My daughters 2008 Range Rover Vogue 3.6 TDV8 is sitting on the bumpstops after getting the "Suspension Fault" and 30mph max message on the dash.
Looking at the error codes, the air spring air supply(algorithm failure) failed first. Then the air supply mechanical failure, then the front left height sensor followed by the pressure signal sensor. I am assuming the last two are because its on the bump stops and there is no pressure in the system.
I can hear the compressor on start up but thats not to say thats the problem.
Any pointers gratefully received. Suspecting a blown air bag, faulty compressor or maybe a broken air manifold as both fronts are showing errors on the 4x4 display on the dash.
Post #720594 30th Jun 2025 10:10pm
Roosterrs
After doing a bit of investigation earlier, the car would not lift. Been back again after about an hour and it has suddenly come back to life and lifted the suspension. It took a while to get up to the off road position but I can hear a leak at the RH front.
Is the valve block on the O/S or near side on a UK car?
Will spray some soapy water on the suspension leg later.
Post #720653 1st Jul 2025 8:48pm
