Home > Maintenance & Mods (L405) > Transfer box oil
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Transfer box oil
Hello all you knowledgeable lot, I'm a novice with the iid tool. I've done the double flush, do I physically have to do anything when calibrating ? Or does the iid do it all?
2017 SDV8 .
Many thanks.
Steve
Post #720705 2nd Jul 2025 5:39pm
fisha
Just do the calibration procedure in the tool and follow any steps. You don’t need to do anything else.
What I will say is that I’m suspecting that the calibration and result when driving on mine may temperature dependant.
I’m definitely feeling that even after flushing a few times now that the typical judder issue on a sharp turn pull away still appears from time to time, and that this appears to be correlating with when the weather is markedly warmer.
For example it’s not unusual for mine to sit for a day or two unused. If I drive it in the cooler morning after having sat for a while, I get no judder appearing. If it’s sat out in the sun on a really hot day, I can get the judder at the first junction going out the street. The only difference is the ambient temp.
I suspect that calibration is so sensitive that maybe thermal expansion is happening or having an effect on the clutch plates.
My point is that calibrating it when it’s warmer may result in a better clutch calibration.
( I think I might try another drain fill and calibrate on a hot day to test this out) V8 or else ...
Post #720715 2nd Jul 2025 9:56pm
Tomo676
Thanks for the reply, keeping my fingers crossed.
I've actually used the Land Rover special transfer box oil.
Post #720730 3rd Jul 2025 6:53am
