Home > In Car Electronics (L405) > Anyone fitted a FITCAMX dashcam?
Rob99
Came across these the other day and liked the way it integrates neatly behind the front mirror housing and almost hidden.
Interested to hear if anyone has one, how easy was it to fit and whether you'd recommend it?
https://fitcamx.com/collections/land-rover...0564531372 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #720802 4th Jul 2025 1:24pm
Kellen
United States
Just installed mine. Really simple. Just pull the overhead console down, trim off the mirror and route the cables.
The mirror may pop off but easy out back on.
3/10 mainly due to the odd contortions you have to do.
Post #720847 5th Jul 2025 2:48am
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
Here is a copy of my earlier post. Very pleased, don't even know its there. First part of story you can ignore Thumbs Up
I recently bought a 2021 Range Rover Fifty & decided to install the Viofo dashcam that I had removed from my Range Rover Sport. Noticed that Powerfull UK now sell a plug in wiring kit which seemed a no brainer as on the Sport I had to splice in the power feed. Part ordered & delivered so removed the overhead console. After trying everything, there was no way to feed the cable through. (They did it on a 2013 model with no sunroof & it was easy) Anyway I then decided to drill a hole n the panel that the docking lugs locate in. Had to be a fairly large hole as the supplied usb connector is right angled. Still could not feed the cable, so unclipped the plastic shroud above the mirror. I then removed the mirror. It is held on with two steel clips gripping a slide. Idea is to slide it off, no way. I then got two vey small hammers & simultaneously tapped a small wing either side of the mirror housing & as soon as there was a little movement it was easy to slide off & unplug. I put some silicone grease on the clips for ease of reassembly. Plenty room for feeding the cable. Then discovered the supplied usb was different to the usb in my dashcam, so had to order an adaptor. Paused the fitting, not a problem as I have other cars.
While waiting & on the net I came across a firm called FITCAMX that supplied the camera built into the shroud below the mirror. Great idea, making it like it was OEM. Censored the Viofo, order in, delivery from China 6 to 10 days (came in about 6 days) When ordering they show a a picture of a few different lower shrouds & you pick the one the same as your car. Mine was model 6111. Also they send you an email almost by return asking you to forward a picture of your lower shroud to ensure the correct item is sent.
Package arrived, really top end box, opened it & there was a new shroud with the camera installed, looked OEM, could not fault it, two small wiring harnesses, one for fitting as per Powerfull UK & other for fitting using the rear view mirror power which meant you do not have to remove the overhead console. Had mine not already been off that is what I would have done. They also supply a 64gb memory card.
Fed the wire through, so easy, connector is round with a slot so it cannot be fitted wrongly, wiring harness plugged in & overhead console clipped back, literally a one minute job. Refitted the top shroud, clips in, plugged wiring socket into the rear view mirror & slid it on to guide & pushed it home. Bottom shroud with camera just clips in, totally as per the original. Switched car on & camera switches on. Couple of lights to show its working, unfortunately they are on the passenger side, but not a big deal. Pair wifi to your phone, add FITCAMX app to phone. This is where I thought I would have problems but totally seamless, worked first time. You can either view footage on the phone or remove memory card & view through PC. They also include an adaptor to fit the memory card which then plugs into the PC.
Early days yet but if you don't like thing stuck to your screen this is what Land Rover should supply
Now got a spare Viofo & wiring harness
See pics in my gallery
Post #720856 5th Jul 2025 8:16am
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
Fitted one to my 2019MY AB last Autumn. Yes, I would recommend and agree with previous comments that it looks totally original to the vehicle and works really well.
I also found that you do need to be something of a contortionist when routing the cables in such a confined overhead space but it’s worth it, especially for the swear box!
Post #720893 5th Jul 2025 9:26pm
Rob99
Thanks guys
@chicb - was also thinking about Viofo so your problem fitting it to your RR Fifty means I will steer clear anyway. Thumbs Up
Sounds positive for the FITCAMX so will stick an order in this week.
Did any of you go for the wired in parking mode and rear cam too? 2021 D350 Fifty Edition - Carpathian Grey
Post #720940 6th Jul 2025 6:59pm
