Home > In Car Electronics (L405) > Rear door card Meridian speaker cover
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Hi all, I have been searching all day to no avail. I have a 2019 L405 4.4 AB that has the 1280W sound system. I am trying to find out if the rear door card speaker covers are replaceable. (see attached photo)
1. Is it possible to buy these speaker covers, specifically the one badged 'Meridian'?
2. How would you swap them out?
I have had the door card off but I cannot see how these covers are removed without causing damage?
 _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #720887 5th Jul 2025 6:25pm
Why not swap the entire door card ?
https://www.ebay.co.uk/itm/356733106325?_s...R4LosLr7ZQ
(I'm not sure this one is the correct colour, so just an example)
Post #720888 5th Jul 2025 6:35pm
ReggieMac
Thanks for the link but they are not the same door cards between the full fat and the Vogue as far as I can tell. If I cannot find the item individually I may well look at getting a whole used door card and so long as the cover is the same colour as my existing I could just swap them. That brings me onto my second question, are they easy to replace without damage? _______________________________________________
Post #720929 6th Jul 2025 5:46pm
ReggieMac
So, got the door panel off today, very straight forward apart from a bit of a fiddle with the door lock cable. After looking closer at the speaker cover from the inside of the panel I could see that the grill was a little loose and is likely what was causing the vibration at certain frequencies. Anyway, a little bit of double sided rubber tape along the inside edges of the grill to fix it back in place and the noise that I thought might have been a blown speaker has now gone! I am so pleased with myself! Thumbs Up _______________________________________________
Post #720971 7th Jul 2025 1:35pm
tomiRR
2013 Range Rover Vogue TDV6 Aleutian Silver
Dear Reggie,
We are pleased with you too!
Mine speaker covers felt a bit in so after reading your case I will also get the bravery, remove the cardboard myself and fix them back to their original position.
Thank you for sharing!
Tom Smile
Post #721122 10th Jul 2025 1:56pm
