Home > Technical (L405) > Can someone advise me what does this fuel line joint does??
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
I'm seeing this H shaped joint for fuel line downstream from fuel cooler/ before LPFP on SDV8 L405 and wondering if this is the return line check valve or it is a different part? It is located inside the wheel arch liner. My fuel system seems to be hitting a bottleneck on return so appreciate any advise from anyone who have experiences with the fuel return lines, check valves and this H shaped joint. Thanks.
Post #720944 6th Jul 2025 8:01pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
Not sure what that is. Has a valve like look to it doesn't it. Looks more like a suction valve though. Maybe if the fuel pressure on the suction side of the secondary pump drops below 0.5 bar this opens up to provide additional fuel volume from the return line. Just guessing here.
Not listed in the parts list. Appears to be part of the secondary fuel pump assembly.
I find that you can push a thin nylon line through these hoses. Like a fishing line. Maybe put one in from the connector on top of the cooler and see if it makes it past that H connection. I used the fishing line to pull a rubber plug through the lines in the engine bay of my TDv6 to wipe the inside of the lines clean.
Post #721248 14th Jul 2025 6:13am
fisha
It may be a pressure relief valve. For example let’s say the tank pump over pressurises its delivery … that valve may open and vent fuel into the return loop and back into the tank , protecting parts further up stream. V8 or else ...
Post #721288 14th Jul 2025 8:03pm
