Home > General > cheap fuel with additive or premium fuel?
tomthespark2011
Morning gang,
So i got thinking, what would be more effective do you think.
1. Buying supermarket fuel or similar cheap petrol and adding a decent fuel conditioner
2. Buying a premium fuel like Shell V power
It works out about £15 a tank more to fill up with V power as a pose to regular cheap fuel so in theory i could put a top quality fuel conditioner in every tank.
But which is better?
It was just a thought i had while filling up yesterday.
That said, im not an expert in this area but i think there are fuel additives and then fuel octane boosters
Post #721299 15th Jul 2025 7:39am
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
Personally speaking, I would not bother. I just use the ordinary stuff from Asda. A few months ago I did a 500mile each way trip & decided to see if there was any difference. Ordinary stuff going & premium coming back. Absolutely no difference apart from the cost
Post #721300 15th Jul 2025 8:11am
bigdave
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
I suppose it personal choice in the end.
Driving a vehicle that can cost £80-120K when new then an extra £15 per tank is a small price to pay.
That and regular oil changes is about all you can do to look after the engine.
I use Shell V power all he time but i only do about 5000 miles per year.
Ive never used an additive.
Dave
Post #721302 15th Jul 2025 8:55am
supershuttle
Always good for a debate. I've tried pretty much everything but cheap fuel, no additives seems to work just fine for me. I do change the oil regularly (every 5000-6000 miles) but thats a different debate and I think there's general agreement about that, well apart from the fact that I never change the filter, that get done around 12000 miles when the car is serviced Very Happy Geoff
Post #721309 15th Jul 2025 12:14pm
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
Choice of fuel and conditioners depends on what it is you're trying to achieve.
Varying brand and type of fuel will show little or no MPG benefits that are worth having. I'm talking a significant change, and not a few mpg.
Many people concentrate on the mpg with no regard for the lubrication aspect of the fuel. I'm referring to diesel in this instance.
Fuel has less of the good stuff than ever, so some research into the content of the additives by various companies can help to make an informed choice.
Fuel pump and injectors will benefit from additives if they're not provided in sufficient quantities in the cheap end of the fuel spectrum.
Finding out exactly what's in the company additives is fruitless as I've never found it published.
As ever, you make a choice, but avoid the trap of basing judgement purely on returned mpg values. Think lubrication and internals.
The additives is a whole world of discussion too, as is the 2SO benefit 🤔 L405 2014 SDV8 4.4 Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #721311 15th Jul 2025 12:47pm
pcourtney
I just use the cheapest diesel around, no problems for 10 years or more, I used to believe all the nonsense about premium this and premium that, but I think it over promises and under delivers for the humble RR driver Smile
What I have done though, is every MOT, she gets a good service, proper oil change, filters etc
and then 4 weeks later I put 350ml of Extralube ZX1 in the engine oil
every 10,000 miles or so, I put about 50ml in the fuel tank, and 3 cap fulls in the coolant tank Smile
https://www.team-zx1.com/extralube-zx1-mic...tment.html
On Ebay its around £60 quid for a litre, but I have three cars, various different engine sizes, so suits me to buy a litre of the stuff, and use it up as and when, I believe the science behind the ZX1 formulation, they seem on point if you read the marketing bullshit Smile
https://www.ebay.co.uk/itm/143591465284
Post #721351 15th Jul 2025 9:01pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I stopped using V Power (which I used to use exclusively) a few months ago and now use Shell FuelSave and add a can of Liqui Moly Super Diesel every fill up.
It works out much cheaper - at circa £8 per tank rather than £20, and I feel that the Liqui Moly is doing more than the V Power (appreciate that is a purely subjective view)
Post #721367 16th Jul 2025 12:10am
chicb
I used to put 250ml of 2 stroke into a full tank of diesel in my previous RR Sport. Lots of posts on RRSPORT.CO.UK forum. Some good reading, snake oil, placebo effect, possibly/more than likely. Anyway I got into the habit of using it, supposed to keep the injectors clean. Don't know if it had any effect but there was no downside. Below is a part of the article. Don't shoot me, I'm the messenger Rolling with laughter
To all interested:
due to the pollution control measures of the EC diesel-oil is nearly sulphur free and contains up to 5% of bio-diesel. Sulphur has the property to grease the high pressure injection pump and the injectors. Without sulphur, the reduced greasing property of the new diesel has already shown negativ impacts on the long-term stability of the injectors and the high pressure pump. The pump manufacturers have tried to react by lining the moving parts of the pumps with teflon or other suitable material. However, the long term stability is still not achieved as with the old (sulphor contained) diesel.
The engine-research centre of a well known German car manufacurer has conducted some long term tests of diesel additives to find out whether any one of them will have an impact on the long term reliability of the diesel engine components. This introduction to explain were my information comes from.
The results of this research: any diesel additive of any manufacturer presently on the market is not worth the money!
BUT: 2-stroke oil, which we use in our motor saws, lawn mower or in 2-stroke motor engines has shown to have an extreme positive impact on diesel engines, if such 2-stroke oil is added to the diesel in a homoeophatic dosis of 1:200. In practical terms: 0,300 litre of 2-stroke oil into the 70l diesel tank. The 2-stroke oil will be absorbed by the diesel (emulsion) and grease every moving part of the high pressure pump and the injectors.
Besides this, the 2-stroke oil will keep the diesel engine clean, as it burnes cleaner as the diesel itself.
In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned. This proven fact delays the DPF (diesel particulate (soot) filter) to clogg, and the "burn free" process of the DPF will be much less.
One more information: in Germany we have to present our cars every 2 years to the TUV -Technical Supervision Organisation - who will check, amongs others, the pollution of petrol and diesel engines.
The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.
The same factor with the use of 2-stroke oil has been 0,47 - reduction of nearly half of the soot particles.
Besides this, the use of 2-stroke oil in the diesel will increase the milage by 3-5%.
Post #721373 16th Jul 2025 8:32am
Rambles
Same as Alex1976
If you think the extra additives put into premium fuels are worth having / have some benefit
And you can achieve same / similar with off the shelf additives and add them yourself to a base fuel
Without paying the extra duty
Then go for it
Some might say you are wasting your money, and they always just use the cheapest derv….ASDA, Tesco City derv….
But that is not the question you asked
You are asking users of premium fuel if they would switch to a base fuel with off the shelf additives to save duty whist retaining some / all of the benefits of the premium fuel
i do this
Post #721400 16th Jul 2025 2:51pm
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
I am someone who up until now has only used V Power or BP Ultimate diesel. However, for other performance diesels in the past I used Millers Oils Diesel Power Ecomax Fuel Additive and was pleased with it. If these days Liqui Moly Super Diesel Additive is the additive of choice then I would consider using that and normal supermarket diesel. Does anyone have further comments or feedback on the Liqui Moly product? "There is no replacement for displacement" - W O Bentley
Post #721409 16th Jul 2025 4:30pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
I know nothing about conditioners, but I do know that V Power makes low speed/town driving a lot nicer as it quietens down the tractor noises vs. supermarket fuel.
Trust shell to use cleaning additives in the fuel as well, saving buying additional snake oil stuff to clean things.
Had not ever done the maths and £15 Sad Doh!
Post #721795 23rd Jul 2025 9:52pm
ilard
I use premium high octane fuel. Same way as my boy only eats organic fibre. Keeps things pumped cleaned for a smooth life. I don't calculate the total cost of ownership for my son. I don't want to think about it. Nor the direct debits and charges for our car which he puked in once For sale soon fyi. (the car I mean) L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #721826 25th Jul 2025 12:04am
Vigilo
Use Premium when I can get it, branded 'ordinary' if not and avoid supermarket (have additive in case I ever do have to fill up with it).
Ran a VW T5 on supermarket diesel and clogged the EGR cooler up - which cost me £600 to get replaced, so learned a lesson the expensive way Some days its just not worth chewing through the restraints.....
Post #721849 25th Jul 2025 12:00pm
