Home > Technical (L405) > Rear Seat Challenges
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I'm trying to get my rear seats in to a position so I can access the fuel pump below them.
Right hand rear seat back moves around 10cm forward and back, from the rear most/most upright position.
Left hand seat back was folded down and now rises back up but refuses to go down again.
It's a 2013 Vogue SE, so the seats backs are the only part that moves.
At one point the right hand seat refused to move at all, then it moved within that range for a bit then stopped moving at all. Now it's back to the 10cm shuffle.
Any bright ideas or suggestions would be most welcome. Thanks.
Post #721410 16th Jul 2025 5:25pm
Martin J
I had trouble with my newly purchased L405 rear seat after lowering and was unable to raise fully.Replace the switches in the boot and now all working. Maybe you have the same problem?
Post #721601 20th Jul 2025 9:20am
Mike Edwards
I think you could be right. After a bit more playing around I found the boot switches work and the problem is with the switches in the seat bases.
Post #721602 20th Jul 2025 10:02am
Martin J
I will keep my fingers crossed.
Post #721603 20th Jul 2025 10:04am
