Home > Maintenance & Mods (L322) > Split pipe….what is it and what does it do?!
Rudyard1
Can anybody help me with identification of this very thin hose and what it does? (Mine has split because I am a ham fisted gimp)
 2007 Range Rover Vogue 3.6 TDV8
Post #721689 21st Jul 2025 9:53pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
It's one of the vacuum hoses, if you can get the broken bit out of the flexi using fine nosed pliers and a bit of heat (I used a small drill bit to get the last few bits out, just by hand, not with a power tool) you might be able to push the rigid pipe back in, they have a bit of stretch in them.
Post #721693 21st Jul 2025 11:08pm
Rudyard1
Thanks for the info - I will certainly try this! Don’t suppose you have any info around what it does??! 2007 Range Rover Vogue 3.6 TDV8
Post #721722 22nd Jul 2025 2:52pm
Red Hot one
The back hose goes to the air filter, the broken one goes to a little block under the turbo hose and coolant hose, no idea what it's function is, there is an electrical connection on top and the vacuum hose disappears down the front of the engine.
Sorry I can't be of more help
Post #721732 22nd Jul 2025 6:08pm
Rudyard1
Awesome - have reconnected and all is well. Thanks for the help! 2007 Range Rover Vogue 3.6 TDV8
Post #721791 23rd Jul 2025 8:48pm
