Home > Technical (L322) > L322 2006 4,2 SC part number for air compressor and HELP
MarioBucolo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Rimini Red
Hello, sorry, my first approach here, I tried a search without success.
I will have probably to change the air compressor, L322 2006 4,2 SC, in London UK
What is the part number? I find some compressor on ebay but want to be sure it work.
Or any advice where to buy in UK a new or refurbished air compressor please?
Anyway this is what happens and friday the car will go to the workshop.
Since when I bough the car, in april, I have suspension fault due to front left sensor that often stop to work.
Before I can change the sensor the car stuck all lowered, messagges "veichle lift slowly" and after "will lift after cooldown". And still give the S fault and the FL sensor apparently dead. I change the sensor, now no suspension fault, the sensor appear working but the car still lower and same messagges lift slowly and cooldown.
There is a chance the car was stuck for the fault and not resetted? I tried also detach the battery but no effect.
Of course can be anything, one of the airbags, the air thank or the compressor.
Thanks for any help
Mario
Post #721692 21st Jul 2025 10:03pm
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
This a good place to start for the part numbers
https://parts.jaguarlandroverclassic.com/p...and-rover/ Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #721708 22nd Jul 2025 10:35am
Jamesh7216
Try RQL500050 or LR041777
Post #721719 22nd Jul 2025 12:30pm
Sandyt
Have you taken off the cover in the boot to expose the pump is it able to vent as there is a filter that can get clogged - there could be a lot of white dust worth a look and there are mods to help it to not get clogged. If it is clogged the pump heats up and then cuts out to cool down .
Post #721904 26th Jul 2025 1:13pm
