![]() | Home > Technical (L322) > Car is shacking at idle !!! |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
One of 6 injectors have failed, g/teed!! Have had this problem before, local indy charged me around £400 to replace with a new one |
J.Seven Member Since: 28 Aug 2011 Location: Estoril Posts: 29 ![]() ![]() ![]() |
Today in the morning while engine was cold everything was normal, no shacking at all, after the engine warmed up it start shacking again at idle. I'm 300km away from home, is it safe to make the trip back home with this problem? J.Seven |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
You haven't just put larger wheels on your TD6 have you (i.e. bigger than 18")?
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
I was going to suggest wheels too. I took my Overfinch 22" ones off and now have a set of 2010/11 wheels on standard size and don't have the judder anymore. |
No I didn't, it's the normal 18". J.Seven |
As i said before i have the standart endros. I think it must he something related to the engine or gearbox/forque converter. J.Seven |
