Home > Maintenance & Mods (L405) > Threaded inserts for strut brace attachment
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
I removed the strut braces from my car, to find that on two of the holes at the bulkhead end the thread is missing, and the bolt had had a couple of bolts put underneath.
I saw a video from Raymie's Garage where he had the same problem, but he had the insert. I don't have the inserts.
Is there a way to obtain and attach an insert?
Post #722050 29th Jul 2025 8:00pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I'm not familiar with the particular part as such but it looks to me very much like it could easily be fixed with a rivnut/ nutsert (others available I'd guess). How easy it might be could depend on the size of the hole and the required thread, but I'd imagine there would be different wall thicknesses and grip ranges available. A rivnut is installed pretty much like a pop rivet, but without the pop.
Chris
Post #722056 29th Jul 2025 9:45pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I think they are designed to be crap from the off!
The ones in the centre of the engine bay can easily be removed and replaced with rivnuts or a nut and bolt.
The ones to the side are up in the suspension towers and are much harder to get to. Not great if some monkey has been in there beforehand so they just spin rather than undo.
Post #722238 2nd Aug 2025 11:48pm
