Home > Maintenance & Mods (L322) > Need help with whining noise
Kalnozols
Latvia 2005 Range Rover Vogue Td6 Rimini Red
I am wondering whether there is any experience with the issues that I am experiencing as neither my mechanic nor myself can appropriately diagnose the issue.
The issue at hand:
Previously I had this whining noise, which was audible only at speeds above 30 kmh, and it was periodical. Periodical as in, not always occurring, some times it did not happen, and some times it did.
Now, 2 days ago, my mechanic removed the handbrake assembly from the rear end, as it was previously thought that it was the issue. Additionally, they stated that they cleared some mud out of the bearing.
After this work being done, the sound has increased tenfold and now no longer is periodical. Whenever road speeds surpass 30kmh, the sound is audible, and can be heard at any music volume setting.
Research is pointing towards multiple possible sources such as differential bearings, CV joint guard issues, bearing issues, etc. But nothing concrete.
Thus, I am wondering if anyone has experienced a similar issue, and whether they found a solution to it?
Thanks
Post #722172 1st Aug 2025 10:56am
Strawman
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Have you checked the rear prop shaft there is a support bearing on there that goes and will make a whirring noise over different surfaces get under the car and give the prop shaft a shake.
Post #722194 2nd Aug 2025 9:12am
