Home > Maintenance & Mods (L322) > L322 heated seats
Vogue66
United Kingdom 2016 Range Rover Vogue SDV8 Corris Grey
L322 heated seats
Hi everyone,
I have a 2012 L322 and the front heated seats aren’t working. Both the driver’s and passenger’s side heated seats don’t warm up, while the rear ones do. I plugged it in a while ago on my Autel diagnostics, and it came up with fault code B1231-7A. Please refer to the vehicle service manual.
When I turn on the heated seat, the temperature shoots up really quickly and then cuts out (without the seat actually warming up). I can hear the fan kick in when it’s turned on, so there’s power getting there.
Does the heated seat use the car’s normal heating system? Because that doesn’t work either due to an unknown fault that I’ve given up on finding.
The cooled function fan kicks on makes a little difference but nothing to much, is this supposed to work from the cars aircon?
The aircon also doesn’t work because of a leak somewhere, so the car is only nice to drive when the weather is exactly right. Very Happy
Post #722715 12th Aug 2025 6:43am
toronnoRR
Canada
Hi, not sure if you've found the culprit, but sounds like the exact same problem I had.
I removed both seat backs, and found the ducting to be cracked. I taped up the ducting and also used some zip ties to keep it from coming undone, and its been working fine for over a year.
There's a person from Ukraine that sells the ducting with a new heating element on eBay.
This problem is also well researched on the forum, have a quick search and you'll find all the answers. Wink
Post #726796 24th Oct 2025 4:00pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Search for peltier unit - that’ll help
Post #726942 26th Oct 2025 9:55pm
mjdronfield
Yes, as above. If you have cooled seats it doesn’t have a heating element for the heating, it uses a peltier unit for both functions.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #726969 27th Oct 2025 10:51am
