![]() | Home > Technical (L322) > Transferbox Neutral and related warnings |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
The topic has probably been discussed ad nauseam but here's my story for what it's worth:
By way of update, cleared the codes and they haven't returned even after quite a few stops while running errands around town. Even the usual "noise on actuator signal " seems absent. |
Seems I spoke too soon. Trans failsafe flashed a couple of times this morning. So I completely removed the potentiometer, cleaned both sides of the male pins down to shiny, bare metal and the female plug with contact cleaner. I then spun the inner ring a few dozen rounds in both directions and was able to do no less than a dozen shifts from high to low without any hiccups whatsoever. Another drive around town for the usual errands and no codes stored.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
It could be cracked solder joints on the potentiometer.
Thanks!
Okay, here we are a few hundred kilometers later and still error-free. Seems that the potentiometer spinning and reseating have done the trick.
