![]() | Home > Technical (L322) > Low coolant warning with new coolant bottle |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 118 ![]() ![]() ![]() |
Hi folks,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1351 ![]() ![]() ![]() |
Are you sure the coolant ratio strength is strong enough because I've read that the floats boyancy is effected if it's too weak. |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 62 ![]() ![]() ![]() |
As kevinp just said - there may be (I have a 4.4 petrol but not yet checked as its still new to me) a level sensor that is fed into the bottom of the tank.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 227 ![]() ![]() ![]() |
Interesting, I have filled the system recently with a 40% mixture, I did 450 miles yesterday (virtually all motorway) and the message popped up right at the beginning of the journey and disappeared after a couple of minutes not seen it on the rest of the trip.
so far so good then. I need to re-explain though as my explanation was not totally accurate:
