Home > Maintenance & Mods (L405) > Fuel burning heater - no cables in the boot
rscsmith
Hi folks
I've just swapped to an L405 from an L322. I love the car, but one of the best features of my L322 was the fuel burning heater with a remote. I could press the button from inside the house and the car would be warm and toasty 20 minutes later.
Looking at the build sheet for my 2016 (65 plate) L405 Vogue SE 4.4L SDV8, it says:
Supplementary Heating Fuel Operated Heater
Park Heating NO PARK HEATING
Engine Pre Heater LESS Engine Block Heater
However, I can't find the cables in the boot to add the remote/timed climate module. I've looked in the location stated in Kev's excellent post here:
https://www.fullfatrr.com/forum/topic57037.html
I have checked under the bonnet, and the FBH appears to be there (again, taking info from Kev's post)
Under the Extras menu on the display, there's no timed climate option.
Is it possible that the car the car doesn't have the cables to the boot, only the FBH? Is it possible to add the rear cabling? Could, perhaps, it have the module but not have it activated (it is mounted out of sight, I understand).
Should I just try editing the CCF (I have GAP IID) and see if it works?
Thanks, Rob. 2007 Range Rover Vogue SE TDV8 (about to be sold)
Post #723044 18th Aug 2025 5:44pm
rscsmith
Think I'll have another crack at it in the morning. Reading more, I may have been too timid in my searching. Will report back. 2007 Range Rover Vogue SE TDV8 (about to be sold)
Post #723045 18th Aug 2025 5:51pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
When you say "I may have been too timid in my searching", I was wondering if that might be the case. It is awkward to get to module. It's high up and to the rear of the vehicle. High up as in you have to get your head in there and look up!
Post #723060 18th Aug 2025 10:00pm
