Home > Maintenance & Mods (L405) > L405 underside - what’s this?
Gremlin500
I’ve recently done quite a bit of work under my L405, but I can’t work out what this is, any idea?
Can’t find anything in the WM above for the item marked in yellow.
 V6 Vogue - “Less is More” - less to go wrong!
Post #723195 21st Aug 2025 4:02pm
Mikey
Big empty plastic box. Presumably for aero or NVH
Post #723219 21st Aug 2025 9:16pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Yes as Mike’s has said. It is simply some plastic trim to provide improved aero under the vehicle. It doesn’t have anything behind it that it protects etc. I took all the plastic off a few weeks ago to clean and then apply Lanoguard. One thing these plastics do is trap loads of mud and stones etc.
Post #723237 22nd Aug 2025 7:43am
Gremlin500
Thanks guys, riddle solved!
The only thing I could find in the WM was that’s the location for the HV battery in the hybrid models, I did wonder if JLR had a mix-up on the production line for a moment! Rolling with laughter V6 Vogue - “Less is More” - less to go wrong!
Post #723248 22nd Aug 2025 10:09am
