Home > Technical (L322) > Drivers side wing mirror not working
sparrowdclxvi
Hi all
I bought an L322 Vogue earlier this year and the drivers side wing mirror has never worked.
I'd like to fix it, and I'm hoping you guys can give me some pointers.
The passenger side works perfectly. Reverse dip, folding when pressing the button, and the adjustor works as well.
On the driver's side, nothing works.
I've gone through all the relevant fuses and they are all OK.
I doubt it's a wiring issue as then some of the functions or motors would work but not others.
Is there a module of some sort that controls these?
Thanks
Post #723301 23rd Aug 2025 11:06am
pcourtney
Try finding a replacement mirror on ebay ( with the correct wiring and features that your car has )
There are three different types of mirror depending on the specs for your car as it left the factory
What year is your L322 Vogue ?
Easy enough to do, I recently had to replace my passenger door mirror, good luck
Post #723361 24th Aug 2025 12:20pm
sparrowdclxvi
Thanks for the reply.
Before randomly throwing parts at it, I'd rather test what I can.
It seems unlikely that all the functions on the mirror would fail. I'd expect the adjustor or the fold to fail, but not both.
The door card has definitely been off before, so I expect someone else tried to fix this, but failed.
Is there some sort of door conrol module?
If not, does someone have a wiring diagram?
Thanks
Post #723377 24th Aug 2025 7:12pm
