![]() | Home > Maintenance & Mods (L322) > Replacing Air Suspension Pipe |
| Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 117
Id guess that most who've done this, self included, will have done it as part of replacing a bag / strut. That being the case it's possible to connect the hose before moving the strut fully up to the mount.
| Jonester Member Since: 16 Aug 2025 Location: North Yorkshire Posts: 10
Yes, my first impression was definitely “this must be far easier without the airbag in situ”. I’m trying to exhaust all options before I have to remove the strut as that seems like a definite case of hammer to crack a nut. Although it is a RR so that comes with the territory I guess lol
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
As Chris says, the general guidance is to fit the air pipe to the bag before you locate the strut in position. You should also do this with the rear bags. This gives you much better access and view, so you can be certain you have done it correctly before locating the strut/bag. .
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
I have replaced the front struts but I don't know if it's possible to just undo the 3 top bolts (+ electrical connector and ARB link) and lower the strut down enough with a jack under it to gain enough access without having to remove the lower part from the hub. To be fair it's not that hard to do even that as long as you have a rattle gun to undo the lower 2 bolts. 2012 TDV8 Vogue (L322) |
| All times are GMT |
