Home > Technical (L322) > L322 suspension/GAP woes
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Well, I've gone and done it.
Was going to replace the rear suspension arms, body mount bushes etc.
When I started I used the GAP tool to deflate the airbags. I expected it would give you a choice for at least front or back but it doesn't, so all bags deflated. Not to worry, it'll get pumped up when I am done with everything.
In trying to go through the GAP menu I couldn't find where it said "inflate airbags"
Then I used my butter fingers and instead of disconnect, I hit unbind.
Now I can't find a password that works so now the car is done having new bushes and whatnot but it won't do anything suspension related Sad
The up/down buttons don't seem to work either, not even lighting up.
The GAP tool doesn't work because 'password'
I tried to disconnect the battery from the car and see if it would start afresh but that doesn't work either.
In short: HEEEEEEEEEEEEEEELP PLEASE !!!
Cheers, Ard
Post #724619 16th Sep 2025 9:32am
toby1
I am sure if you email Patrick at GAP he can help you. 2012 Vogue TDV8 in Aintree green over sand
Post #724621 16th Sep 2025 9:36am
Dutchgit
ThanksToby, I did that Thumbs Up
Post #724626 16th Sep 2025 10:33am
Dutchgit
Got into contact with Patrick and with the previous owner of the GAP tool and after some emailing back and forth all is well in the world and things are looking up as does the suspension going up ! (and down when required)
Cheers, Ard
Post #724646 16th Sep 2025 7:58pm
