![]() | Home > Technical (L322) > Fuel pressure too high P0088-22 |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 313 ![]() ![]() |
Basic check first and I am sure you have, but is the fuel pressure sensor on the LH rail connected and undamaged? 2012 Vogue TDV8 in Aintree green over sand |
From the manual for that code:
BRONZE BEAST Member Since: 11 Jul 2024 Location: Leeds Posts: 19 ![]() ![]() ![]() |
The fuel pressure regulator is on the left rail I think? The fuel pressure sender is on the right rail. As far as i can tell with a continuity meter the wires are intact. There maybe a fault in the sensor. That will be checked with new sensor I guess. |
Fuel pressure sender fault is favourite
