Home > Technical (L322) > 'Check Spare Tyre Pressure' Message 2012 L322
robkuijpers
Netherlands
Hi Folks
This subject has been covered in this forum a few times, but without definitive conclusion.
Got this message since a few days (maybe since I had another space wheel in the back).
The tyre pressure was indeed a bit low, but now I topped it up, the message does not disappear.
Does it mean the pressure of the tyre is under or above a threshold value, or that there is no connection with the TPMS valve (eg battery depleted). I already turned the wheel half a rotation, but not effect. Where is the TMPS sensor located for the spare?
Any suggestions?
Rob 2012 RR Vogue 4.4 TDV8 Sumatra Black
2004 Defender 110 Td5 Epsom Green, 'Alive' Chip tuned and a Warn 8274 Winch
1978 Citroen Mehari Orange Kirghise
2001 Defender 90 Td5 Softop (gone)
1992 RR Classic 300TDi 'Soft dash' Green (gone)
1989 RR Classic V8 Caspian Blue (gone)
Post #712367 21st Feb 2025 8:53am
Try taking the spare out , drive for a day or two then put the spare back in....this might reset the system. ... - .- -.
Post #712372 21st Feb 2025 9:36am
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
I have exactly the same problem. Turn on car gives me 10 seconds of check spare tire and goes away. No matter what I tried does not make the warning go away…any advice is highly appreciated. Since it goes away after 10 seconds i dont even know how to check other than turn on and then off the car, which is not ideal. Range Rover 2012 4.4 TDV8 - current
Range Rover 2008 3.6 TDV8 - previous
Range Rover 2004 3.0 TDV6 - previous
Post #725048 24th Sep 2025 8:14pm
GraemeS
Australia
My MY21.5 L405 comes-up with the same message yet the build specs state that no spare wheel TPMS detector is fitted. L405 D350 SE Carpathian Grey D5 19" rims
Post #725049 24th Sep 2025 9:57pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
A new TPMS fixed this for me
Battery in old one was flat
Post #725050 24th Sep 2025 10:01pm
