Home > Technical (L322) > New bonnet fitted issues
Apps
United Kingdom 2010 Range Rover SE TDV8 Santorini Black
Has anyone fitted a new bonnet to there l322. I fitted a new one but now it won't lock properly. Wen I pull the bonnet release it doesn't make the click sound its like something has happened to the cable
Post #725093 25th Sep 2025 5:30pm
dingg1
Yes, no real problems with it, probably just needs a slight adjustment to the retainer pegs and the adjustable spacers that screw into the bonnet
Post #725094 25th Sep 2025 5:35pm
jomal
Switzerland 2010 Range Rover Vogue SE TDV8 Santorini Black
Hey
I never personally fittet a new bonnet to a RR but what u can do if the bonnet lines up with the body, is to losen up the screws from your latch so much that it can be moved hard by hand. Then u close the bonnet and the lacht moves it self in the right spot. Open the bonnet again and tighten those screws and vola 2010 Range Rover Vogue 3.6 TDV8
Post #725097 25th Sep 2025 5:36pm
Apps
Thanks. I think the issue im having is the x2 brackets each side of the bonnet that clip down when closing the bonnet as when I press the release bonnet it doesn't spring up like it did when the old bonnet was on
Post #725098 25th Sep 2025 5:47pm
