Home > Maintenance & Mods (L405) > Check coolant level
Danwilderspin
Check coolant level
just out of paranoia from finding out there is no oil pressure or oil low sensors on the 5.0 I just wondered if someone could confirm they at least tell you when the coolant is low?[/i] Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #725733 7th Oct 2025 7:43am
fisha
The tdv8 does in mine. V8 or else ...
Post #725750 7th Oct 2025 11:09am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Dan, do you believe yours doesn't have a low coolant level sensor? The V6 ones definately do.
It was one of the main problems with the old P38's as they had no low coolant sensors and there was no notification of a coolant problem, which resulted in easy overheating, which resulted in the slipped liner problem on the 4.6 engines, which resulted in more coolant loss and more overheating.
Surely JLR have learnt from that fiasco. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #725761 7th Oct 2025 2:12pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Re: Check coolant level
2018 low coolant for sure
Post #725804 7th Oct 2025 10:30pm
