Home > Technical (L322) > left side air intake not intaking air
lazarus31
hello everyone i have a problem with my l322 4.4 tdv8 2012 range rover vogue. At first it give me a warning restricted performance mode then i stop the car for 10 minutes drove home with no problem. but the day after car started but in rough idle almost no power i couldnt pass my garage ramp (almost 30 degrees) then i checked the forum. i cleaned donut pipes replaced them did a smoke test no leaks but i notice something .My driver side air(left) pipe was not sucking air. right side is normal no problem. is my turbo charger dead or is something stuck in pipes ? i removed some of the pipes but didnt see anything. what should i do next
Post #725789 7th Oct 2025 7:34pm
I assume it's the same as the SDV8 where one side feeds the secondary turbo and only kicks in at higher revs.
https://www.fullfatrr.com/forum/topic65440.html
Post #725790 7th Oct 2025 8:03pm
lazarus31
but it wont go up to 2400 rpm either
Post #725791 7th Oct 2025 8:07pm
GraemeS
Australia
You need to find out what fault codes are occurring.
If you're checking for air being drawn in on the left side when revs are above 2400 then that is normal as the secondary turbo will only be operated when there is sufficient load as well as sufficient revs. L405 D350 SE Carpathian Grey D5 19" rims
Post #725793 7th Oct 2025 8:48pm
lazarus31
p1247 is the fault code
Post #725795 7th Oct 2025 9:01pm
Have you read these - https://www.fullfatrr.com/forum/search.php...rch_time=0
Post #725801 7th Oct 2025 9:56pm
