Home > Technical (L322) > Car dead - what the heck have I done?
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I'm in the middle of replacing the heater blower using Gary's excellent guide in the wiki. I'm at the stage of testing the motor, it's all installed with the cover still off. Reconnected battery and note that interior lights work, central locking works and sidelights on due to light switch being disconnected for the job in hand.
However, the car does not respond to the ignition button, nothing, dead (the key is in the car by the way). The light on the starter button is on. Nothing on the dash lights up. The only think I've done additional to Garry's guide is that I removed the instrument binnacle because I thought (wrongly) it might give me better access. That has all been reinstalled though.
Any ideas? It's as if something has tripped off or a fuse has blown (no idea which fuse to look at). Any assistance gratefully received.
I should add that the battery is new, fully charged and it has a new alternator. It all worked fine (except the blower motor, obviously!) before. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #725985 10th Oct 2025 4:43pm
Mikey
IPC, heater panel and key antenna need plugged in the let the car run Thumbs Up
Post #725989 10th Oct 2025 7:55pm
rvbush
Thanks Mikey, all that’s not plugged in is the main screen on the dash and various minor lights. It did occur to me that this could be the issue, but the guide seems to suggest not. I’ll try plugging the screen in tomorrow and see what happens. Drives:
Post #725991 10th Oct 2025 9:14pm
rvbush
Gigantic sigh of relief time!! Turned out to be a dodgy connection on the back of the instrument binnacle. Took it out again, spray of switch cleaner, reassemble and all working as it should.....Phew! Drives:
Post #725999 11th Oct 2025 12:39pm
