Home > Technical (L322) > DPF sensor readings
claeszv
Denmark 2011 Range Rover Vogue SE TDV8 Santorini Black
DPF sensor readings
Hi
Can anyone tell me the voltage reading on the dpf sensor when engine not running.
IIdtool says 7.3 volt but the only information I can find is that it should be 5 volts. fitted a ned sensor but readings are the same
I have a full dpf 27.5g and locked in limp mode
L322 2012 4.4 TDV8
Post #726411 18th Oct 2025 9:22pm
Baltic Blue
The only way to clear the limp mode red DPF is to do a Forced Regeneration .
It’s very easy, just follow iid screen instructions.
Post #726438 19th Oct 2025 11:36am
