Home > Technical (L322) > alternator on its way out?
mgrover
so the alternator.
i noticed on cold mornings if i instantly put both heated seats on and the front/back screen, the heated seats are turned off.
is that a sign of the alternator being on its way out or just standard behaviour? i am close to 180k miles so no issue if i have to replace it.
also would my life be easier if i just took the condenser/radiator/bumper off for access when doing all this work and probably the pulleys too?
cheers Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #705259 23rd Nov 2024 6:40pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Before condeming the alternator I'd be checking the battery. I put mine (2007 tdv8 3.6) on charge every few months and am surprised that it will always take a charge as its driven regularly, but mainly short trips ( I know, I know). Obviously a lot more power usage in the colder months, and it's about now that batteries that are marginal start failing.
I dont have an iid tool so can't say what that might say regarding charging etc, but I guess it would give insight?
Chris
Post #705294 23rd Nov 2024 11:16pm
mgrover
i can take a look at the battery. i did make the mistake of letting it die when i was working on it.
but i took it out, charged it back up and it sat for 2 weeks on bench and didnt drop at all. Its actually a sport Sad
Post #705305 24th Nov 2024 9:29am
JayGee
Sounds more like the battery esp if it's been alowwed to drain to zero - how old is it? A failing alternator should throw fault codes as the charging system is heavily monitored. 2012 TDV8 Vogue (L322)
Post #705306 24th Nov 2024 9:34am
mgrover
couldnt be more than 2 years old
but the battery starts and runs fine. Its actually a sport Sad
Post #705309 24th Nov 2024 9:57am
A failing alternator usually has a couple tell tales signs.
1. You'll get the red battery light coming on intermittently, increasing in occurrence, and will eventually stay on.
2. A whining noise from it.
Easier to rule out the battery as replacing the alternator is "challenging", especially in the winter months.
I know, I did it twice Whistle Censored Big Cry Got - 2017 SDV8 Autobiography in Loire Blue
Post #705344 24th Nov 2024 4:03pm
mgrover
no red battery light at all
i just wanna beat it before it leaves me stranded given its mileage.
ofc today was 10c so no dramas there. Its actually a sport Sad
Post #705345 24th Nov 2024 4:10pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Have a look in the secret menu and see what the battery voltage is / what it’s charging at when running.
.(like Alan said, changing the alternator in Winter is not fun. I did mine between Christmas and New Year. At least I couldn’t feel it when skin was removed from my hand at the time…). 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #705346 24th Nov 2024 4:13pm
mgrover
am defo planning on waiting for better weather tbh
this is just the planning stage Its actually a sport Sad
Post #705347 24th Nov 2024 4:23pm
davidrosenbloom
2009 Range Rover HSE 4.4 V8 Chawton White
Alternator voltage at idle
So I plug in my GAP tool and in the left upper side I see 12.2 v on my 12 5.0 L322 which is odd because I have an 09 L322 4.4 and I just did an alternator and the minimum is 13.2 at idle. SO I take the 12 for a drive and I watch as value jumps from 12.2 down to 12.0 in RED and then up to 13.5 and then 14.5 and then down to 13.7 and its not linear at all; Battery Management system or not, I cant see us sitting at 12.2 which we did for five m, then I get on the highway and it jumps to 14.5 and then down to 13.0 were it sits until we get home and it holds 13.0 at idle.
If this were any other car I'd immediately think failing voltage regulator but on this thing I just dont know. Battery is brand new and topped off. No red lights on dash.
But interestingly GAP wasnt happy working or giving me a whole lot of info at this voltage at all. Just parked it in garage.
Has anyone seen anything like these numbers at 90k miles and have an opinion as to regulator or BMS? CHecked GAP against three voltmeters and it was spot on.
Ill even take thoughts...
Dave
09FFRR
12 FFRR
Post #726940 26th Oct 2025 9:34pm
mgrover
the only thing id say is
the left upper side reading is pretty crap, i wouldnt rely on it.
id use one inside the menus if you are checking Its actually a sport Sad
Post #726964 27th Oct 2025 9:54am
dingg1
2007 Range Rover Vogue SE 4.2 SC V8 Stornoway Grey
Sounds like the rectifier is on its last legs ,same happened to me about the same mileage, bushes and bearings were fine but rectifier had died
Post #726968 27th Oct 2025 10:37am
JayGee
Re: Alternator voltage at idle
Sounds normal for the later car BMS system regulating the charge depending on demand on an AGM battery. Like I said you will get warning lights if courtesy of the BMS monitoring system if the alternator is not operating within it's set parameters. 2012 TDV8 Vogue (L322)
Post #726979 27th Oct 2025 1:31pm
dingg1
Jays probably nailed it ,I got the red non charge light on the dash
Post #726982 27th Oct 2025 2:05pm
