![]() | Home > Technical (L322) > Wing mirrors, reversed operation of tuck in motor |
For some reason one of my wing mirrors has reversed its operation!
Yeah, happened to me too. There are 2 fuses in behind the glovebox, can't remember which numbers right now. Remove them both and operate the powerfold button. Replace 1 of them (doesn't matter which) and operate powerfold again. Replace other fuse and operate powerfold. All should now be well.
Woohoo cheers Dom, will sort that tomorrow morn web I have the nipper climbing round te interior lol |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I had this problem (only it was one up, one down) with the headlights on a TVR... solution was £800 at the thieving bas |
Fuses 11 and 24 in the main fusebox located behind the lower glovebox.
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Use the search this has been mentioned before and the solution is much simpler than taking out fuses. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Many thanks for taking the time Dom... I shall have a go this morning...
Cheers Dom its worked a treat |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Which one? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
wiki,
