Home > In Car Electronics (L322) > 4x4 Info Screen displays wrong height text
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi to you all!
Just wondered if anyone else had experienced this with the touch screen system?
When I select a height change whilst viewing the 4x4 Info page the car icon at the top shows the height change in progress and the wheel/chassis bars move too but the text to the right of the car icon remains showing the original start-up ride height.
The only way I have found to change it is to alter the ride height, shut the car off and let it go to sleep then re-start and the selected height will now be correctly displayed.
The dealer has upgraded the software to the latest available with no luck and it has them beat too! 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #82206 18th Sep 2011 4:14pm
do you do the adjustments whilst the range is stationary or moving, if stationary maybe the figure will change when you move. ... - .- -.
Post #82207 18th Sep 2011 4:18pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
lol...it doesn't take much to confuse most dealers, especially if testbook and software is involved!!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82253 18th Sep 2011 6:56pm
RichTD6
I've tried changing it both moving and stationary and the result is unfortunately the same scarey.
Even tried altering the height before switching to the 4x4 Info page and no joy.
I know its not a major issue but I just like everything to work as it should where possible and I know some may say thats too much to ask on a Land Rover! 2012 Westminster TDV8 4.4 Indus Silver
Post #82418 19th Sep 2011 3:26pm
just checked mine, it has a car icon and the word access to the right,
switch on engine and switch to standard and there is an up arrow to the right of the car icon and the word raising to the right.
when it reaches standard the car icon disappears and there is a horizontal line in its place and the word standard to the right...
hope this helps.. ... - .- -.
Post #82420 19th Sep 2011 3:33pm
RichTD6
Thanks for looking on yours scarey.
Tried the same procedure as you but the word access remains to the right even after the car icon has gone and left the horizontal bar.
Sad 2012 Westminster TDV8 4.4 Indus Silver
Post #82644 20th Sep 2011 6:10pm
what 'year' nav disc you using, the 2009/2010 disc upgrades the firmware.. ... - .- -.
Post #82645 20th Sep 2011 6:12pm
RichTD6
I have the 2011/2012 disk and I remember it did do an upgrade when I inserted it. 2012 Westminster TDV8 4.4 Indus Silver
Post #82749 20th Sep 2011 10:56pm
scratching me head now....the only thing that 'might' help is dis-connecting the battery and hope that when the nav boots up again it'll sort it self out...btw ,take the nav disc out until the battery is re-connected... ... - .- -.
Post #82785 21st Sep 2011 8:28am
RichTD6
Okay, thanks will try that at the weekend and let you know how it goes. 2012 Westminster TDV8 4.4 Indus Silver
Post #83012 21st Sep 2011 10:06pm
RichTD6
Well, a little late I know, but I finally got round to trying disconnecting the battery and have to report that it made no difference, I'm sorry to say. Sad
Any other ideas on this one? 2012 Westminster TDV8 4.4 Indus Silver
Post #109292 25th Feb 2012 11:48am
Patricktet
2006 Range Rover Vogue Td6 Buckingham Blue
I have the exact same problem. Did you solve this? Anyone with a solution? Im also using the latest 2011/12 navdisc.
Post #209477 11th Sep 2013 8:32am
RichTD6
Sorry to say I've not solved it yet unfortunately. 2012 Westminster TDV8 4.4 Indus Silver
Post #209578 11th Sep 2013 4:50pm
