![]() | Home > General > What to look for when buying a 03-05 Vogue? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
peter, i've moved this to general as there is a lot of info about buying ranges here ... ... - .- -.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
the gearbox is got to be top of the list, check it changes smoothly, no shuddering, put it in drive and just touch the throttle,keep it light and let the car pick up slowly,look around 25 to 40mph for any type shuddering. then do the same in manual mode and go up and down the changes, check the kick down. see what service history it has on the box as this can be very expensive if it goes wrong. V8 facelift Range Rover Autobiography 22" wheels.
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Even doing all those checks to the gearbox is no gaurantee it will be ok. I ran the whole list of checks, looked at the service history - the box had been replaced 22,000KM ago, and serviced 12 months after that. Everything checked out, and it worked like a charm. Second time I drove it after buying it, and the trannie blew up. |
That's the key. The ZF box has it's probs - but that would not have happened on a box that had no probs after the rebuild. And why no guarantee? 22k km's on a rebuild/exchange is $hit. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Just to let you know Gav's ( The Brains Trust ) gearbox was the GM 5L40E. He has a TD6
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Mine lasted 16K miles after rebuild... |
