Home > Maintenance & Mods (L322) > Windscreen Buzz
Windscreen Buzz
Ok I've given it a search and this noise seems to stem from the lower windscreen shroud, but mine is coming from the top of the screen right behind the rear view mirror since i gave the car and good cleaning yesterday Sad
Im guessing its the trim at the tops of the screen, ive checked and its taut and in place other than at the ends where it is a little floppy for about 1-2cm but the rest is good Sad
My buzzing starts at about 48-55mph and only gets worse as speed increases but when i've looked i cant find anything loose and the only other thing i can think of is a windscreen wiper component vibrating and the noise travelling up the screen due to the wind at those speeds Sad
My windscreen hasnt been replaced recently and hasnt in the previous owners ownership from what i can tell as there isn't anything in the dosc to show it.
any help mucho appreciated as i may have to try some duct tape over the mid section where i think it comes from and see if it helps.
Post #84574 29th Sep 2011 1:49pm
SteveMFr
Site Sponsor
Check the a-pillar covers (the entire visible a-pillar is just a plastic cover). Most windshield shops stick these down when they cause probs, but the probs are usually just the clips.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #84576 29th Sep 2011 1:53pm
Cheers Steve will give them a check when i go to pick the nipper up from school Smile
Post #84578 29th Sep 2011 1:58pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
wow...a "chelsea tractor" on the school run in yorkshire!!!
wouldn't have happened in my day!!!... Laughing Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #84595 29th Sep 2011 4:21pm
Ha ha, maybe i should take a video of the route i take to show its more tractor than chelsea Wink
in the heat wave today the AC was lovely for me and youngest nipper waiting, turning the rear up, then the centre console then the rest of the front up to max icing ability Very Happy
Post #84668 29th Sep 2011 8:55pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
It'll be at the bottom of the screen, my first FFRR had this problem and it was a dead simple fix, and it's a common problem, I found it with 5 minutes searching on the web. Thumbs Up
Here ya go, see post by RRVSE! Thumbs Up 2012 SDV8 Vogue SE
Post #84682 29th Sep 2011 9:40pm
Checked bottom scuttle and one or two of the fixing type screws seem loose but everything else around the screen seems tight Sad
Selotape will be tried next week on a part by part basis to see what it is i guess Sad
Thanks for your help though guys Smile
Post #84803 30th Sep 2011 7:07pm
PS which post by RRVSE?
Post #84804 30th Sep 2011 7:08pm
Googsy
King
This happned on mine. Did you check the rubber trim at the bottom of screen mine was not sealed hence the noise I used some black sealant to seal that I got in Halfrauds. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #84807 30th Sep 2011 7:16pm
You mean a rubber to seal the scuttle to the bottom edge of the screen??
Post #84808 30th Sep 2011 7:23pm
Googsy
Thumbs Up Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #84847 1st Oct 2011 12:17am
bogie
I had this earlier in the year really bad and annoying
try black tape all along scuttle seal to windscreen, if that works, theres your issue...you could use some black silicone to seal it up but thats a bit of a bodge if you are not neat n tidy
I think the plastic can warp slightly in the sun over the years and it only takes a tiny gap for it to become a reed valve against the screen and make the bee buzz at 50mph or faster
I got fed up, priced up a new scuttle panel (£40ish) and its like new and perfect again now Smile cheers
bogie
Post #84887 1st Oct 2011 3:41pm
