![]() | Home > Technical (L322) > Deodorising the Air Con. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
The easiest way is to try a can of ac system cleaner from someone like Halfrauds. Comma Air Conditioning Cleaner is what you need.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
typically known as 'bombing'.... ... - .- -.
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 226 ![]() ![]() ![]() |
My main dealer uses Fortron air conditioning treatment.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Warning...very old thread resurrection coming!!
i bombed mine paul cos there was a smell when the ac was off ..its possible that maybe a filter change somewhere will get rid of yours rather than a bomb but it worked for me.... ... - .- -.
Cheers Stan... |
I can confirm that the air con treatment worked to remove the musty smell. |
Gents...apart from the Pollen Filter (located under the bonnet just in front /centre of the windscreen) are there any other cabin air filters?
No Paul, just the one sir |
Cheers Craig |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
My recently acquired L322 had a very slightly damp/musty smell with the a/c switched off. I did an oil service and also changed the pollen filter. So far I have not had the smell come back.
