Home > General > 18" rims on a TDV8
A1GSS
18" rims on a TDV8
Anyone able to confirm if these fit properly, and if so what are the correct tyre sizes ...?
Prefer 18" for my winter rims.
Thanks. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #85370 4th Oct 2011 11:17pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Correct size is 255/60/18 I think
You'll need newer 18" wheels to ensure they fit over the brembos FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #85374 4th Oct 2011 11:38pm
simon1233
I know of a couple of guys who have added compomotive 18 inch wheels to their RRS's so they can use more aggressive MTR tyres. Look up Flydive from the D3 and RRS forums. Apparently the only thing he had to do is alter the orientation of some weights on the brembo's by 90 degrees to ensure adequate clearance...
The weights were added to TDV8 RRS callipers to reduce break squeal. Don't know if they were ever added to the FFRR?
Post #85375 4th Oct 2011 11:43pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
18" on a 3.6 yes i think so 2009 onwards 18" , but not on the 4.4TDv8 min is the newer 19" Far to many gone...
Post #85382 5th Oct 2011 7:53am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I would have thought if the TDV8 has Brembos, then it would be 19" minimum? 2012 SDV8 Vogue SE
Post #85387 5th Oct 2011 8:57am
I will soon be selling an as new professionally refurbished set of 18" with as new Premium Yokohama Geolander Winter Tyres.... Whistle
Not sure about the fit though.
Post #85407 5th Oct 2011 11:08am
A1GSS
Ah right, could be interesting...
Anyone know the definitive answer about whether 18s will fit? Graham
____
Post #85424 5th Oct 2011 1:42pm
GregP
I pretty sure any 18"s that came on a 2002-2005 FF will not fit over brembos. Could be wrong mind. FFRR TD6 HSE
Post #85428 5th Oct 2011 2:43pm
simon1233
Extracted from a mail from Compomotive last week
'We have just completed the process of confirming all the fitments for this new wheel on the many varied Land Rover brake options / vehicles.
We have supplied for all model of Land Rover with this wheel via our Australian importer = www.greenovalexperience.com . I have attached an image of a late model car fitted with our rims.
However if you have the early Range Rover Sport model of car that is fitted with the Brembo branded brake caliper there is a problem with the steel blocks that are bolted onto the brake caliper itself.
These would need to be removed or relocated to allow the fitment of an 18” rim. These steel blocks are simply bolted to the rear of the caliper by a single Allen headed bolt.
Sorry to say that these is no way around this problem and such alterations should only be undertaken by a competent engineer. The blocks are there to stop a vibration squeal that the early cars suffer from when these blocks are not in place. For 2010 year model cars, the brake brand and construction was changed so the fitment of an 18” rim has become less of a problem with the Compomotive rim.
Due to a model change in the Land Rover line up - The 2011 year model 5.0 litre Supercharged Range Rover sport now has even larger Brembo branded brake calipers that does not allow the fitment of anything smaller than a 19” diameter rim. So this means that we do not have a rim available for this exact vehicle.
The rim model is made to take your original Land Rover alloy wheel lug nut and Land Rover centre caps. So it is just a case of just fitting your new tyres, adding these accessories and driving away from the garage with your news rims fitted.
The rim price is £175.00 gbp each – plus tax and transport.
The cost of transport to your door for 4 rims would be £30.00 gbp plus vat.
[Not including any local taxes that may be payable if the sale is outside the eurozone.]
You can use the regular 255 60 x 18 tyre or 265 65 x18
We recommend the following for touring and medium off-road work:
General Grabber AT2 255/60R18
Continental CrossContact AT 255/600R18
Yokohama Geolander AT/S 265/60R18
Cooper ATR 265/60R18
Goodyear Silent Armor 265/60R18
For more serious off-road (but will need light plastic cutting):
BFG AT 265/65R18
Cooper Zeon LTZ 285/60R18
For very serious off-road (will need more modification):
Maxxis Bighorn 275/65R18
Hankook MT 275/65R18
Regards
Barry
Components Automotives 73 Limited
4/6 Wulfrun Industrial Estate'
Upshot is that their Compomotive PD1880 8X18 rims do fit over Brembo's. Flydive told me that he has just rotated the weights on the back of his brakes by 90 degrees so that there is adequate clearance but the weights remain in place to stop the brake squeal. I don't know if the Brembo's on the FFRR suffered the same problem so the weights may or may not be there.
Don't know if standard landrover wheels have adequate clearance, but as the boys with their RRS TDV8's are fitting these over landrover rims they could get much cheaper I am guessing the answer is not...
Simon
Post #85430 5th Oct 2011 2:53pm
johnson1
If your vehicle has Brembo brakes, I am highly doubtful the 18" will fit - I believe even the original 19" will not fit over Brembos, except perhaps 2010MY onwards 19" wheels which are standard on Vogue derivatives.
Post #85431 5th Oct 2011 2:53pm
A1GSS
It's a 2007 TDV8 with the standard Brembo TDV8 calipers. It has standard FFRR 19's on at the moment, all good so far.
I wanted to get some 18's for winter.... sounds like it might be a non starter? Graham
____
Post #85434 5th Oct 2011 3:04pm
why not stick with the 19'' , they'll be just as good in the snow... ... - .- -.
Post #85435 5th Oct 2011 3:07pm
A1GSS
Probably will do just that, Tons of them around too. Graham
____
Post #85437 5th Oct 2011 3:10pm
simon1233
mine came with 20 inch rims and they have now been downsized to brand new vogue se 19 inch wheels with new pirelli scorpions for the winter.
Ebay bargains Thumbs Up
Fitting 18 inch wheels seems very expensive when you have the brembo brakes
Post #85441 5th Oct 2011 3:21pm
A1GSS
Right. I'll probably have the winter tyres fitted to my current rims and buy some new rims in the spring...
Thumbs Up Graham
____
Post #85445 5th Oct 2011 3:28pm
