Home > General > Parking sensor
barrieeld
Parking sensor
Anyone know where the best place to get a parking sensor?my front ones don't seem to be working. Are the easy to fit? I was goIng to get my bumper resprayed anyway so won't paint them just yet.
Post #86114 8th Oct 2011 9:28pm
Johnte
Maybe stating the obvious.. But you have turned them on haven't you ?
I'd had mine a few weeks before I realised I needed to turn the front ones on by the switch Embarassed Embarassed
Post #86116 8th Oct 2011 9:54pm
barrieeld
Switch??
Post #86124 8th Oct 2011 10:33pm
switch on the dash, or select reverse first then the fronts will be activated. ... - .- -.
Post #86126 8th Oct 2011 10:40pm
A1GSS
Ah. You learn something new every day... Embarassed Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #86129 8th Oct 2011 10:45pm
barrieeld
I just assumed when you select reverse the park distance control comes into play both front and back? Back works fine but no beeping happened when am object is close to fri t bumper?
Post #86134 8th Oct 2011 11:29pm
you assumed correctly...if after selecting reverse you find the fronts are not sensing then there is a fault ..btw ,it would help if you could update your car profile.. ... - .- -.
Post #86139 8th Oct 2011 11:59pm
A1GSS
Why is this.. can it be changed e.g. with a Faultmate or soem hidden (to me) menu, so they're always active below say 5 mph? Graham
____
Post #86143 9th Oct 2011 1:40am
imagine you're in a traffic jam , the sensors will be going off all the time.. ... - .- -.
Post #86159 9th Oct 2011 10:03am
Im sorry, but why would you want them on every time you slow to under 5mph??? I could think on nothing more irritating!!! (apart from my Mrs watching strictly!)
They get set off by every blade of grass within 10ft... Imagine driving in rush hour!!! OMG!!!
Why can't Land Rover make a set that work like they do on my Discovery 11? Excellent things & 5yrs older then my FF... Progression huh!!! Rolling with laughter
Craig Thumbs Up
Post #86161 9th Oct 2011 10:06am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
There's a few posts on here about front sensors not working. Is it all four?
Check the wiring but also brace yourself for a knackered channel on the PDC module (in the right rear of the luggage compartment bolted to the back of the fuse box) think they make the modules in the dark.
Post #86168 9th Oct 2011 10:21am
A1GSS
Um. Fair points... I've got them on the Audi and they just seem to work, I've never switched them on (or off) and never had a problem in traffic or whatever. It's maybe a question of their sensitivity / proximity of the object being sensed...
Whatever. Graham
____
Post #86171 9th Oct 2011 10:29am
johnson1
That's in the Mercedes system - always bloody come on below a certain speed. SO ANNOYING.
Post #86190 9th Oct 2011 11:41am
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i had them in my VW Touareg and they were always on but it didn't seem to bother me, living in the sticks they don't beep much... Laughing
with regards to your front sensors, i would check them first before you looking for wiring issues.
if you activate them, and then put your ear on each one in turn, you will hear them ticking if they are working. obviously one that doesn't tick is broken.
they are a fairly easy fit, pop up on ebay quite often or one of the big L/R spares places don't charge that much for them. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #86246 9th Oct 2011 6:26pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
These vids may help
Post #86334 10th Oct 2011 2:49am
