![]() | Home > For Sale & Wanted > Wanted Alloys and Tyres x 4 |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
You have to lift the suspension to its highest first., should come off the ground easily enough. This jack has a lift of about 14" (ie the difference between lowest & highest) Graham
As I'd used it on my D3 a few times I was pretty happy it would be OK but as I had NOT not used it on the FFRR and in the interests of accurate research, I just went and got a bit oily...
ALWAYS lift suspension to Offroad setting before jacking. If you do not the wheels will just hang down as you Jack making life impossible without a very big jack. THe trick is that the suspension is already fully extended and therefore the wheels will not droop as the chassis is lifted. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless Iām not at home, in which case Iām somewhere else. Posts: 6823 ![]() ![]() ![]() |
Thanks guys! Got - 2017 SDV8 Autobiography in Loire Blue
One on with the LR scissor jack
Yes. It's a jack of no trades |
Ordered a paddock jack! |
So Mick do you like them? |
Well £10 a wheel change and i need to get them done tomorrow , so the cars sitting with 1 x 19" Alloy
. 1 x 20" 06 SC Alloy (was the spare) and 2 x 2010 design Alloys on the drivers side
Wont know until i put the four on Gaz
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
The Paddock jack is just the job , I have one to |
Takes me a lot longer than 13 strokes of the pump handle |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
@ Mick. I get all 4 changed for £20 Mick. Pay no more! |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Bring it down here Mick and I'll change them over for you |
