![]() | Home > General > Hypothetically speaking........... |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Given you already have the S/C and love it I'd recommend getting it LPGd. That way you can keep the car you love but also not be stung too much with running costs. FFRR TD6 HSE
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
That's my initial thoughts, especially since I think I've got a good 'un (touch wood), but I just wonder wether Mr Chancellor will start to bump up the tax on LPG, making it less of a saving in years to come? Got - 2017 SDV8 Autobiography in Loire Blue
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Definitely go with the first option! Why would you want to go for an oil burner after enjoying the S/C? Only pain with the LPG'd S/C is the range, furthest I've seen is 280 miles, however you've always got petrol to fall back on, just dilutes the economy a bit! 2012 SDV8 Vogue SE |
Go with the LPG route but maybe get the toroidal tank and an underslung one on the passenger side a well if they will let you.
Also been weighing up the options al , but don't think i could go the LPG route having previously had the 3,0 FFRR and now the SC , i think i would like to try the 3.6 TDV8 rather than the 4.4's ……….
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Having read a copy of the new MOT Inspection Manual for MOT's as from 1 Jan 2012 I would advise against cat removal on any spark ignition engine ie petrol, lpg etc as a cat not in place on a vehicle that was fitted with one at manufacture is a "fail". As far as I can tell cat removal on diesels will still be ok. |
There is no exemption for anything to do with LPG in the existing Mot Testers Manual, it actually states "This inspection applies to all petrol, diesel and gas powered vehicles".
