Home > Technical (L322) > Aircon O-rings - yes or no??
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Following the saga of my bust heating - the first garage said the evaporator had split, the garage fixing it said it wasn't the evap but the O rings on the evaporator. I haven't got the car back yet but they say they've changed them and the aircon has charged up OK. I recall the P38 had a well-known heater O ring issue; do our L322s have something similar? I just want to validate what the garage are telling me.
Cheers.
Post #87435 14th Oct 2011 7:26pm
I don't know about L322 O rings specifically but O ring leakage on car ac systems is very common. You get O rings in the pipe to equipment joints such as compressors, evaporators and condensers.
Not a big job to change, usually all the work is in dismantling bits to get to the joints together with recharging the system with refrigerant.
Post #87469 14th Oct 2011 9:49pm
Cappo
Thanks, yes, that does make sense, just checking the garage as it had to go back to the supplying dealer and therefore I don't know how good the repairers are.
Post #87511 15th Oct 2011 7:58am
