Home > General > Whats tomorow going to bring? 3 days of ownership
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
ooof! thats a biggie Shocked ,have got a bit of a transmission judder on mine but i am hoping an oil and filter change may help this and its nothing terminal (fingers crossed) Neutral
Paul Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #88582 23rd Oct 2011 2:54pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
I hope you're right. Not sure if you have the V8 or the TD6. The V8 runs a ZF auto, which is less prone to premature failure, but the TD6 uses a GM box that has known issues. I always thought I may have to do the trannie one day, but I never expected it to be this soon... Neutral
Cheers - Gav
Post #88838 25th Oct 2011 9:47am
If your having suspension issues on LPG then check your compressor location and angle of install... Just like a conventional workshop compressor they are designed to work one way up only and suck in moisture etc when mounted incorrectly...
Craig Thumbs Up
Post #88841 25th Oct 2011 10:01am
marsie
Gav i am running a 4.4 with the zf auto so hopefully you are correct Neutral . Good point Craig,my compressor is mounted out of its shell on a custom made bracket next to the gas tank in the spare wheel well. Started i up tonite for the first time since saturday and the compressor ran for at least a minute even though the air susp inactive light and message was on Yawn
Paul Thumbs Up Paul
Post #88909 25th Oct 2011 7:42pm
The Brains Trust
Hi Paul, as mentioned the ZF generally has less issues, but they do have a few quirks. There is a very good thread on this trannie - http://forum.landrovernet.com/showthread.p...4-teardown
This guy seems to everything about these beasts, so if you post him a question on what yours is doing, he may be able to tell you if you are in for trouble or not.
Cheer - Gav
Post #88965 26th Oct 2011 9:26am
marsie
Cheers Gav,make for a very interesting read and as you say this guy Bemble seems to be a whizz on ZF autos. Will give him a shout. Interesting to note that he very definately warns against dexron oil Shocked
cheers
Paul Paul
Post #89025 26th Oct 2011 6:50pm
Bemble a.k.a. RRPhil on this forum Smile .
Post #89028 26th Oct 2011 7:04pm
marsie
Even better Thumbs Up Paul
Post #89029 26th Oct 2011 7:17pm
marsie
Well,first time out since monday and it hasnt failed to disappoint Rolling Eyes ,todays new fault-cd changer,was working fine then came up no discs and mag wont eject Censored
must keep smiling Neutral
Paul Thumbs Up Paul
Post #89336 28th Oct 2011 7:50pm
ebajema
It is maybe worth taking all the electric connectors off and spray them with WD-40 or CRC 2-26. Also disconnect the battery leads on the battery and clean the inside surface of the clamps of the leads and the battery poles. Then put a thin layer of vaseline on it to prevent any corrosion.
When I got mine it had been sitting still for 2 years and it showed a lot of faults in the beginning. The battery wasn't great either but before I changed that out, I did the connector trick with a lot of the connectors and the problems slowly disappeared.
Also check if all the connectors are "tight", take them out and make sure they go back on being tight. Check if they are not too loose causing intermittent contact.
Also check the belt/tensioner and alternator, to make sure your battery is properly charged. Do a check on the voltage at the poles of the battery while the car is running and with everything switched off. Even a new battery can fail sometimes.
Hope you get rid of the issues soon, that is when you will be able to really enjoy the luxury and comfort a FFRR. MY 2010 5.0 SC Galway green and sand interior!!
Post #89337 28th Oct 2011 8:03pm
marsie
Thanks Ebajema,may give it a go. Fixed the cd changer the old fashioned way,gave it a whack and it started working again Mr. Green ,nice to know that the Range rover responds well to cheap fixes Thumbs Up
Paul Paul
Post #89381 29th Oct 2011 1:47pm
ebajema
Clearly wasn't an electrical fault then Smile
Good luck with the rest ! MY 2010 5.0 SC Galway green and sand interior!!
Post #89383 29th Oct 2011 2:39pm
marsie
Mr. Green no,i guess not. Had a full day today with no faults Bow down . Maybe its learning?
Paul Mr. Green Paul
Post #89425 29th Oct 2011 7:11pm
