Home > General > What oil goes in your TD6?
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Just had my TD6 serviced at Main Dealer in Ashford, Kent.
They have put 5w 30 Magnetec in the engine at £10.99 / litre!!!! Shocked
I would have expected, and did expect, that they would have put a 0w30 Fully synthetic in the engine, especially as BMW have issued a directive that all theit engines, apart from M tech, should only have 0w 30 oil in them.
So, my question, Seeing as these cars have intelligent servicing intervals of at least 10k miles do you use fully or semi synthetic in your engine?
I have taken this up with the group principle of the Dealership as their servicing team don't seem to want to answer my query on both price and oil choice! Evil or Very Mad
I told him that I am extremely dubious of letting them have the TDV8 in for servicing! 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #88867 25th Oct 2011 1:52pm
I have mine serviced at a main dealers and they use Shell Helix fully synthetic 5W40 . Mind you I have had it for four years and in that time the have failed to demonstrate any real stupidity . Very Happy 2008 MY Supercharged
Post #88869 25th Oct 2011 2:12pm
5W-40 Magnatec in mine. They are an old engine designed many years ago and don't require fully synthetic oil of up to the minute modern engines
Post #88871 25th Oct 2011 2:30pm
rayc
Hi interesting point you make
But BMW have issued a directive to all their dealers that these engines, and others, must be run with 0w30.
My 5 series runs on 0w30 fully synthetic and has never used a drop.
I just feel semi synthetic over that period of time is not good for the anti wear factor personally. 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #88874 25th Oct 2011 2:47pm
When the BMW engine was designed fully synthetic oil was not common place.
I had a Mercedes that I bought new in 1999 and kept for 11 years, the oil was changed every 15000 miles always Magnatec and it clocked up 200,000 miles before I sold it. The new owner has now had it for 2 years and still changing the oil every 15k and clocked up another 35k miles and never a problem.
Post #88881 25th Oct 2011 3:39pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Even doing my last service myself i spent about £90 on the "correct" 5w 30 Magnetec, Costco do a Castrol Magnetec full synthetic but not 5w 30, its about £30 cheaper so whatever it is im using it next time. 2004 black Vogue TD6
Post #88947 25th Oct 2011 10:13pm
From the Owners Handbook '02 model
Engine oil - Diesel vehicles
Use a 5W/30, 5W/40, 5W/50 or 10W/40 oil meeting specification ACEA:A3 and B3 and having a viscosity band recommended for the temprature range in your locality
NOTE: Use only fully synthetic oil
Engine oil temperature ranges
0W/30 will protect from -30oC to 35oC.
0W/40 will protect from -30oC to 50oC.
5W/30 will protect from -30oC to 35oC.
5W/40 will protect from -30oC to 50oC.
5W/50 will protect from -30oC to 50oC.
10W/40will protect from -10oC to 50oC.
But...from the slightly later handbook (USA spec I think)
Engine oil
Use a 0W/30, 0W/40, 5W/30 or 5W/40 oil meeting API service level SJ/CD, EC11 and having a
viscosity band recommended for the temperature range of your locality.
NOTE: Use only synthetic oils.
0W/30 will protect from -22oF (-30oC) to 95oF (35oC).
0W/40 will protect from -22oF (-30oC) to 122oF (50oC).
5W/30 will protect from -22oF (-30oC) to 95oF (35oC).
5W/40 will protect from -22oF (-30oC) to 122oF (50oC).
Whistle .
Post #88950 25th Oct 2011 10:30pm
Im looking at getting these for mine,
Oil
Service Kit
Oil Catcher
So im total i reckon its going to be about £180 for a service, BUT the oil will do another service and have 2 litres spare, and have the oil catcher for next time so the next service will cost me a total of £40 Smile
So
1st Service £180
2nd Service £40
So within 20k miles the car will cost £220 in NORMAL services(its a range rover it will break!)
Not bad for £110 for a full service because god knows how much a normal garage never mind a dealer would charge!
Post #88951 25th Oct 2011 10:32pm
Well if you dont tow or do any hard work on your TD6 then the 0w30 should do, but I tow upto 2tonnes with kit in the car as well a lot so ill stick with the 5w40 me thinks Smile
Cheers Joe90, normally OilMan does posts like that IME :p Very Happy
Post #88953 25th Oct 2011 10:48pm
letsavit2
basically then any good fully synthetic oil will do, whatever is the cheapest at the time. Can't remember what costco was doing but it was castrol full symthetic for diesels, about £28 for 4 litres.
king pleb, just put a 99p bucket under in off road mode.
Do you guys all go by the computer, my last service was about 14 months ago but still have 6k left according to the computer. 2004 black Vogue TD6
Post #88956 25th Oct 2011 10:58pm
Well i do either milage or age, so every 12months or 15k i'll do mine but need to do it soon anywy and the gearbox.
the bucket method is a good idea though Very Happy
Post #88957 25th Oct 2011 11:03pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I use an old wash basin (lower in height than a bucket) Smile
Post #88959 26th Oct 2011 6:23am
mzplcg
A tip for you all. Keep an eye on the bargain web sites where the offers are mailed out to you daily. I got the heads up on an offer at Tesco on the Castrol oil for the TDV8 and it's also good for the Jag 3.0 TDV6 in Wifey's XF. Main dealers charge £12 a litre for this stuff and I got 2 litre packs at Tesco for £6.50. Needless to say I bought a stack of them, about enough to do 2 oil changes on both cars.
Register at places like Quidco etc (there are a lot of others) and make sure you get an email every day. You can save loads Thumbs Up
Post #88961 26th Oct 2011 7:59am
rayc
Seeing as fully synthetic oils are supposed to give almost zero wear and doesn't break down under heat or long use (Being "synthetic") I think it really should be the obvious choice whether towing or not?
BMW X5's which has the same lump in 3 ltr diesel guise is Castrol Edge 0W30 from BMW or and compatible 0w30 oil.
Possibly a can of worms opening here!
But I would think for longevity reasons the Synthetic route must be the obvious route?
I'm going to dig deeper into this one! Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #88962 26th Oct 2011 8:45am
rayc
Just had an email from the dealer.
5w30 Magnetec professional is indeed fully synthetic they tell me! Embarassed
So it appears the old synthetic technology has become synthetic oil.
No worries, it can stay in the engine!
They still haven't told me why it's £10.99 a litre from them for less than £6 / litre retail!
We'll see Thumbs Up
However, got this from Castrol's web site
Edge 5W-40
LAND ROVER incl. RANGE ROVER
Range Rover Td6 3.0 Turbo Diesel DT
2002 - 2004
Engine (DT) Edge 5W-40 (e) 8.8 Magnatec 5W-40 C3
alternative Edge 0W-40 A3/B4; B3S 0W-40 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #89008 26th Oct 2011 3:22pm
