Home > Maintenance & Mods (L322) > Rear Subframe mounts / Body mounts - anybody done them?
fisha
The RR had a few advisories after passing its MOT:
Rear subframe mounts Left
Rear subframe mounts right
Rear left brake pipe corrosion
Rear right brake pipe corrosion
Rear upper left bush wear
Rear lower left bush wear
Rear upper right bush wear
rear lower right bush wear
Laughing
the guy laughed and said " at least you've got a year to fix em ! "
There is plenty of info on the web regarding the rear bushes ... i'll probably invest in a bench press anyways ... so I should be able to manage them
But what about the subframe/body mounts. Having a look under, I guess its those big fat bushes about 3 to 4" in diameter, one in each corner of the subframe.
Has anyone changed these out?
Are the a major major job requiring the whole subframe out? or can hey be done in situ?
thanks
Don V8 or else ...
Post #88870 25th Oct 2011 2:27pm
