Home > Technical (L322) > Injector Overhaul
Olders
Injector Overhaul
Hi all,
Has anybody had the injectors on a TDV8 overhauled?
I am looking for a price comparison, both from a main dealer and an independent (I.e. an injector specialist as the indie is unlikely to be able to do this properly).
I have had a fault code for injector 8 show up. This was cleared and hasn't come back (although the symptoms have), however a fault code on injector one has now cropped up. This was also cleared and I am going back in tomorrow to have the codes read again to see if either has returned.
I have had the symptoms again, so I am expecting a further fault code Crying or Very sad. My only thought is to have all eight overhauled (hence the question on likely cost as I want to be armed with this when I speak to the garage) - any other ideas?
Cheers! Thumbs Up -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #88967 26th Oct 2011 9:32am
If time is no object then have the injectors removed and bench tested. You could possibly get away with just a refurb.
Post #88978 26th Oct 2011 11:03am
