Home > General > do you like your back end exposed.
keep noticing that the back underside of the range is sort of un-finished and a bit ugly looking so i was wondering if theres a bit of aftermarket plastic that can be bolted on to give it a smoother look.. ... - .- -.
Post #89274 28th Oct 2011 1:27pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
best thing to do is keep the exhaust system clean and painted. Mine was looking good until I got the pressure washer under there to blast some dirt off. Damn thing took some paint off as well and it now looks alittle naff. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #89276 28th Oct 2011 1:36pm
i did the same , painted everything in view but it soon gets dirty.. Neutral ... - .- -.
Post #89278 28th Oct 2011 1:41pm
GregP
prob best waiting until next spring now as anything you clean under there now won't stay clean for long.
We've got the Salisbury trip as well which could be messy if this weather continues Thumbs Up FFRR TD6 HSE
Post #89281 28th Oct 2011 1:47pm
Googsy
I cleaned mine although on the later versions it doesnt appear to be as exposed as the earlier versions. Scarey if you clean it and spray it with WD40 it keeps it looking good and the WD40 prevents a lot of the crap from sticking. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #89293 28th Oct 2011 2:10pm
i'll try that mate Thumbs Up ... - .- -.
Post #89295 28th Oct 2011 2:11pm
GregP
yeah, I'm gunna try that as well.
good tip Thumbs Up FFRR TD6 HSE
Post #89296 28th Oct 2011 2:12pm
Googsy
Scarey / Greg good thing is with the WD40 also is you dont really need to clean it as spraying it on is simple and takes a few minutes even hides dirt if you cant be bothered cleaning it Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #89297 28th Oct 2011 2:14pm
I also am a lot happier with my tow bar in place (it came with the swan neck but I fitted the two bolt flange type so I could use my bike rack with it). Gives me an extra sense of security against those approaching too fast from behind! .
Post #89306 28th Oct 2011 2:39pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Followed a rangie today with overfinch badging on it (was a pre facelift like mine) and that had a lower section under the bumper and the exhaust pipes poked through? Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #89325 28th Oct 2011 5:23pm
We fit lots of these!!!
And if you spend more, you can have one of these fitted... Both cover the unfinished bum!!!
Craig Thumbs Up
Post #89403 29th Oct 2011 5:26pm
that one in pic 1 is a nice solution, you'd have to cut and extend the pipes as well i suppose... ... - .- -.
Post #89406 29th Oct 2011 5:44pm
Cant be to hard can it? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #89409 29th Oct 2011 6:19pm
You dont need to as they are designed to take the standard exhaust downswept end pipes, but yes you can cut and extend them or fit dummy ones or have none on display... Thats the beauty of this undertray Stan...
Craig Thumbs Up
Post #89410 29th Oct 2011 6:19pm
very nice craig , thanks for the pics.. ... - .- -.
Post #89442 29th Oct 2011 8:27pm
