Home > Technical (L322) > "rear water ingress"
Page 10 of 11 <123 ... 91011>
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Roughly £70ish from memory Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #129922 8th Jul 2012 2:06pm
Blinkinlights
Canada 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Please add me to the ever growing list of those afflicted with water ingess in the spare tire well of my 2006 HSE. I am eagerly awaiting the arrival of a replacement air compressor tomorrow and have taken steps to identify the source of the leak. Here is a video of my attempts earlier today:
https://vimeo.com/46200795
I think that the leak on my FFRR is from the armature hole on the passenger side (right hand here in Canada) so I hope to remove the bumper tomorrow and seal up the holes. Any tips on the bumper removal?
Thanks for all the info so far. 2006 HSE
Post #132450 23rd Jul 2012 3:08am
Vogue
I have also now discovered the obligatory leak! I am not going to waste much time on this, so took the easy option and removed the two rubber drain plugs adjacent to the air compressor - far easier to manage water that has got in and give it an easy way out - hopefully!
Have also been troubled with repeated condensation from new, not from the recent leak though, hopefully the plug removal should stop it.
Post #132554 23rd Jul 2012 4:50pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
after reading this tread went and had a GOOD look for any tell tale signs of water leak on my 2007 tdv8.,
bearing in mind that it was quite warm last week the spare wheel well etc showed no sign of past/present water damage.
there was however a plastic bag that was sealed over the satnav/dvd compartment.
was this placed because the previous owner had issues or was it part of factory fitted.
also found the door bump stop in the middle of the drain channel was not even bolted on!
so just as well i performed the inspection..
next stop... back wiper motor modification as per wiki!!!
Post #133609 30th Jul 2012 3:44pm
Luckyluciano
Has anyone got the part number for the boot seal? Range Rover Autobiography 5.0SC
Range Rover Vogue 4.4 V8 SOLD
Aston Martin V8 Vantage
Post #217882 21st Oct 2013 1:33pm
Luckyluciano
Just in case anybody needs the part number it is; LR024161
Currently it's £93 Range Rover Autobiography 5.0SC
Post #218063 22nd Oct 2013 11:45am
Mustard
Good timing in resurrecting this thread as Ive recently suffered my BlueTooth module being totally destroyed by water and wiping out my entertainment system. A fibre optic bypass quickly had all my particulars visible again, thankfully Thumbs Up
Removing the inside trims of the D pillar revealed that the water has been pouring down both of them also soaking the wadding thats on the inside of the trims. Seems to be pouring down & collecting mainly all over the electrics side of the boot and has gingerly filled the bluetooth module but thankfully nothing else. Took the roof lining down, removed roof mounted ariel and then proceeded to seal that back onto the roof with a liquid gasket solution. Looks like it has made a difference but it hasn't solved it, few drips are still getting in somewhere around the D pillar......
Seeing the price of the BT modules I dont think Ill be in a hurry anytime soon to replace it.
Post #218151 22nd Oct 2013 10:11pm
Welshdragon
Well not that I wanted start a new thread but to resurrect this old thread for any newbes on here, this is a reminder to check your boot.
For a while in this wet cold weather my FF has been very slow to clear the glass inside, so few days back while we had a break from the rain and on a frosty clear day I was checking the spare wheel well... Shocked Shocked Shocked Shocked
If the spare wheel could have a bar of soap and a rubber duck you would of swore it was having a bath in there, wet and frozen, looks like I have a few jobs to do. Crying or Very sad Crying or Very sad
Only good news is the left and right side compartments are bone dry........for the time being Rolling Eyes If it dont work.......burn it!
Post #302575 3rd Jan 2015 10:20pm
Mustard
Yep new rear aperture seal (boot seal) fixed any remaining leaks for me, thankfully next to no damage occured Bow down
Post #302578 3rd Jan 2015 10:24pm
Welshdragon
Thumbs Up good to know fella, Thumbs Up that's another job to do on mine! Laughing If it dont work.......burn it!
Post #302587 3rd Jan 2015 10:29pm
miggit
If your after a boot seal, Dan at Duckworth Parts is your man, He's at least 20% cheaper than anyone else that I looked at Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #302624 4th Jan 2015 10:19am
cbmcpa
United States
nicedayforit wrote:
Or in some cases one of these might be useful
www.force4.co.uk/831/Rule-500-Bilge-Pump--...3godnX37FQ
LOL..
Post #305075 14th Jan 2015 3:53pm
CEEGEE
Without wanting to tempt fate, I feel really lucky - the boot is completely dry and the tailgate appears completely rust free Thumbs Up
Post #305086 14th Jan 2015 4:34pm
miggit
Sshhhhh! The Mighty Sod might hear you and make it rain for forty days and nights in your boot Shocked Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #305115 14th Jan 2015 7:04pm
cbmcpa
United States
hi all..
2004 RR
my water is definitely coming from above the amp (as the amp is wet - and 1st one destroyed) -
so not thinking its the bolts in the bumper - looked under there - could see nothing..
possible coming from the front sun roof? would HATE to have to remove the headliner Sad
hung a dry rid (or whatever its called) in that compartment (Driver Rear)..
thanks..
Post #305135 14th Jan 2015 8:26pm
