Home > General > Photo Required - Behind N/S Front Arch Liner
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
Gents,
Before i go home and get stuck into taking out the N/S front arch liner, does anyone have any photo's (or a bloody good memory) as to where the sunroof drain hose appears?
I've tracked it all the way down from the roof, under the car ontop of the air compressor tank, and into the wheel arch from under the car.
Any help is much appreciated! Thumbs Up
Post #89696 31st Oct 2011 4:27pm
Never had to look for them but this is whats written in the Workshop Manual.
"Drain hoses are connected to the front and rear corners of the frame. The drain hoses are located inside the 'A' and 'D' post pillars to allow water which has collected in the frame to escape. A one-way valve is fitted to the end of each
drain hose to prevent the ingress of dirt and moisture."
Whether it helps you or not I don't know. Smile
Post #89697 31st Oct 2011 4:37pm
kriswilson
Perfect. Least now i know what i'm looking for just not what it looks like! Its a start. Thanks very much ! Thumbs Up
Post #89700 31st Oct 2011 5:07pm
Just remembered.
I fitted front mudflaps to my car recently which involved releasing the rear of the wheel arch liner to fit the mounting brackets, I don't remember seeing any drain pipes in behind and I did paint out the metalwork behind the arch liner with grease. I'm sure I would have noticed them.
On my Disco previously the sunroof drain pipes also dropped down inside the A
post and actually stopped short of the bottom of the A post and drained down inside the post. There was a drain hole in the bottom of the post to let the water out.
Post #89701 31st Oct 2011 5:15pm
kriswilson
Well done young sir. 100% right, nowhere near the front arch contrary to everything I've read over the last few months.
All sorted and water flowing freely through the drains Cool
Whoop whoop, £550 landrover?! F*%# off!
Post #89732 31st Oct 2011 8:23pm
A1GSS
How did you clear them through...? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #89734 31st Oct 2011 8:24pm
kriswilson
Did you see my other post where Cam Tech Craig mentioned about the air compressor tank nipping the grommet ? Well he was spot on!
I started off by taking the arch liner out, side grill off, bottom fender off, inside A pillar off, inside kick panel out over about 2 hours. Then I had a bright idea that if I pour water down the drain tube that works and see where it exits, logic dicates that the blocked tube should empty the opposite side. Back under the car at the near side, when looking up, I could see quite clearly (when you know where to look Rolling Eyes ) that the compressor tank had indeed caught the grommet and push it up, crimping in between the frame and the tank.
From that point on, maybe 15/20 mins total. Loosen off both 10mm bolts holding the tank up (hint: don't lie directly underneath! You will, like I did, get very wet Big Cry ) and manoeuvre the grommet back into the frame securing it tightly back in place. Test with numerous jugs of water, flows like a river!
Jump up and down with joy for 5/10 mins. Then spend an hour putting back all the parts you never needed to remove in the first place! Thumbs Up
I can take a photo of the grommet location if it will help anyone.
Post #89739 31st Oct 2011 8:35pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
It would be great if you could post a pic.........just incase I need to find this grommet in the future !!! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #89744 31st Oct 2011 8:59pm
Good to hear you got it sorted without involving "professionals".
Post #89746 31st Oct 2011 9:11pm
kriswilson
Ok gents.
Here is some quick iPhone photos of the grommet i mentioned above:
As you can see there is not much room between the tank and the grommet. It must have been knocked or thrown back on it a hurry for it to knock and bend the grommet out of place.
Hopefully its of some help. I should of taken another showing its location under the car but its about 6 inches from the first jacking point under the car. You cant miss the start of the air tank anyhoo.
Post #89769 31st Oct 2011 10:20pm
CG-SC
Good pics, thanks....
So is the grommet where the water drains out from ? I am presuming that when it becomes dislodged, the water just discharges inside the car ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #89772 31st Oct 2011 10:35pm
kriswilson
no probs.
yeh, the drain tube comes down the B pillar (not the A pillar as i've read everywhere) and down into the frame between the front and rear doors. The grommet is the attached to the end of the tube.
What happened in my case was the grommet somehow got caught by the air cylinder and lifted up out of position and held tight against the framework. Basically blocking the tube completely from the grommet upwards. After very heavy rain when moving the car and turning a hard right the build up of water in the drain tube would rise to the top of the sunroof and trickle down into the cabin. Not good!
Post #89775 31st Oct 2011 10:47pm
Glad you got it sorted my friend... Hope the info helps other forum members too...
Craig Thumbs Up
Post #89796 1st Nov 2011 12:30am
