![]() | Home > General > 2011 front headlight LED problem/not working |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8100 ![]() ![]() ![]() |
2011 has LEDs - I'm fairly sure you can't change them & shouldn't need to - its far more likely to be a bad connection.
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
hi mate, tbh i thought that was the case but i stupidy went to a bulb website and it showed an actual bulb for a 2011 headlight.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
what alistiar says, loose connection.. ... - .- -.
cheers guys, ill have a dig around and also take a pic tomorrow hopefully i can get a quick quick crash course on the set up of such electronics |
Racking my braind (to no avail) on this one - it does seem odd that both front indicators have gone - I wouldn't have thought they have any common cabling and havig a dodgy connection on both at the same time seems unlikely...... |
right guys, i went out and took some pictures because it was really annoying me.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
you will find the other indicators working due to the resistors in the front, they will act as they are still working, again its strange that both have gone, i would be inclined to check the head light first as these led's cant be changed, not read any faults like yours on the conversion, so check your headlights and if they are working then you can start checking connections.
Hi Daveo,
WAIT A MINUTEEEE, JUST AFTER DAVEO SAID TO HAVE A LOOK AT ALL THE LIGHTS...
just to rule out the head lights can you test the led's with a supply from your batt, V8 facelift Range Rover Autobiography 22" wheels.
you would have to take the headlight out.. to be honest i dont think your prob is there but i would check any way..i would say the LCM... have you had any programming done on it, 2nd have you disconnected your battery at all. V8 facelift Range Rover Autobiography 22" wheels.
edit.....please dont use the quote button to reply ... ops sorry |
