![]() | Home > Maintenance & Mods (L322) > whats the best LPG conversion |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
I recently had this same debate, about a month ago lol
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
how do you rate the install and what did the install cost you, how can i see your pics V8 facelift Range Rover Autobiography 22" wheels.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I got mine done at Euro LPG in London, under £2.5k all in. That included twin BRC genius max reducers, high capacity injectors, BRC electronic flashlube system, largest available tank, discreet filler bracket under rear bumper.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1557 ![]() ![]() |
I have a Romano setup in my current 4.4 RR.
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Capital Autogas fitted a BRC system to mine 35k ago. Great Company, excellent service. 5.0 supercharged autobiography
I've got a KME system fitted by Andy Evans Autogas by me and can't rate him enough. Will get a few photos for you tomorrow so you can see, or not see my install as the case is. It's super discreet. The BMW engine is great and takes gas really well. You don't need flash lub as the cylinder heads are rock hard unline others. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Mine was around 1900 i think 1922 off the top of my head
my mate is booking his up to get done next, as for running costing i can get 83 litres of gas in the tank (which is a 92ltr tank) and it does around 230-280miles per tank |
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
I have only had my car a week but its fitted with a BRC system, it runs really nice on gas and as got a 95litre tank in the spare wheel well, I would have liked the filler to be fitted a bit more discreetly but you cant have everything. I used to run a 4.7litre jeep on a OMVL system but overall impression the brc seems to better. |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Cliffy,my install is pretty much identical to yours with the 2 differences
well it seems the BRC is rated, the next big question, the air compressor |
When they done mine with the compressor they relocated to the corner section on the o/s so i lost the tub under the carpet but my compressor is under there |
My install is also the same as Cliffys. As I had to replace the air comp I put in a Prestonair bracket. Makes a nice tidy job.
I'm confused, are you guys saying it was relocated to the offside, or remains under the floor?
